Hey Guys:
How would I add an Avatar to my profile? I'm assuming an Avatar is the small picture that appears below the profile name. Thanks.
How Do You Add An AVATAR (Picture) To A Profile?
- IslandHopper
- Master Flub Spotter
Go into your 'profile', towards the bottom is the avatar options. You can upload an image of your choice (60x60 max size), or link to an existing avatar somewhere else.
One of the things I've been meaning to do is setup an Avatar Gallery. I should be able to do that pretty soon.
Hope this helps
Hope this helps
- IslandHopper
Thanks for the reply James. When I went into my profile and into the Avatar Gallery, there were no images available and no categories to select from. I guess, my only other option is to upload an avatar from some other site, but I do not know where to go to do this. Any ideas?
- Little Garwood
- Carol the Dabbler
James says that the max size for avatar images is 60 x 60 pixels. The thumbnail screen caps are 96 x 72 (and the full-size images are much larger than that), so they would need to be cropped and/or have their resolution decreased a little. Other than that, I don't see why there should be any objection.
